New Computer set up
Either VM or drive cloning.
I keep a clone (fully cloned disk....not an image file) of my laptop HDD.
On a regular basis I update the clone.
Then...any issues or a new laptop......I just bring out the clone and duplicate the new disk.
You will notice a hardware clone does not need software install or a PC.
It just builds a cloned disk by duplicating (cloning) the original disk to a new disk.
The USB is for using a disk as a spare drive.
Using a dedicated disk duplicator is not something I have considered as a backup / cloning option.
Just so I understand the process... you regularly remove the hard drive from your laptop and place it in the duplicator to create a cloned disk?
When the PC is first setup and fully updated with Win7 updates......I clone it to the new disk.
After I install all the necessary software.....and it is running fine......I clone it again and over write the original clone (you could start a new "backup" clone and save the "original").
Then....on a regular basis as the installed disk gets more WIN7 updates and installed programming software updates, I clone over the "backup" clone.....to keep it up to date.
The best use of the duplicator is in my supplied systems. I am an OEM + Integrator.
I always buy the same Dell PC to supply with the job. When the new PC shows up, I just pull the HDD and clone it to my backup clone.
Ready to go......Updated Win7 (and ALL the correct Windows settings),Adobe reader, GE Proficy Machine Edition, Intouch and DAServer setup and ready to go.
Has anyone installed Hp laserjet pro 4203 to OMNI 3000 or 6000 via ethernet..Is there a specific Config? I have a problem..Please advise
73
A project recently went through to replace an old computer that was running Wonderware with a new computer. After a bit of work I was able to get...
481
I would like to temporarily install AdvancedHMI on the same computer as FactoryTalk View SE. I am waiting for another contractor to finish the FTV...
580
My customer wants me to set up their industrial computer hmi running factory talk view se client in the following way. They want to use a single...
1,052
Hi everyone. Ifix scada is new for me. Please help help me to clarify is it possible to open Ifix scada runtime on dual monitor and how to do? Thanks
475
