New product
I've had quite a few problems with the 700HL relays.
When using with the 120VAC output modules, I've had them stay on even though the output was off. I understand that this is due to the leakage current of the output module so I went with their "handy dandy" "Built-in LCSC (leakage current suppression circuit)120V AC and 125V DC". Unfortunately I just got finished swapping one out after a few months of running. This was on a drive that the "start" signal was off and the drive kept running.
I am now debating on whether I should start replacing the several hundred I've installed.
Hello All, I'm looking for some opinions and Ideas for guarding the product entrance of a palletizing robot cell. Please see the attached...
523
Respected Members; I am going to design the PLC control system. The requirement as under: 1. Input/ Out put modules are SIL 2 certified. 24...
425
I've got an issue opening a project in TIA Portal v16. When the file is opening, I get the message that says "Optional products used in the...
743
I am new to Siemens, and just looking into their HMI software. Does Siemens have a product similar to FactoryTalk View SE? I am looking to have...
1,765
I am speccing out a system for some burner controls and the customer has two SLC500s that will need to be upgraded. There is no distributed IO. I...
25
6,664
