New PV+ for old. Can't talk to MLX1400
DairyBoy
Jun 2007
UK
393
I had to replace a hosed-down PV+7 (2711PT6C21D8S) which connects directly to a MLX1400 via ethernet (no switch). The addresses are static and there is nothing else connected.
On installing it, I couldn't get it to communicate without inserting a switch in line. I guess that I must have set up the original PV somehow to achieve this but I can't work out what that was (if anything).
If someone could please help jog an addled brain, I'd be very grateful.
Thanks you.
I've been "remote-controlling" a junior for this job, but yes; both ping and RSLnx sees them individually. X-over arriving tomorrow and a little DIN-mount switch going there too.
What do we have? an older junior trying to remote controlling a younger junior?
Mickey, thank you for taking the time. It's not where I expected to find the problem -too focused on the PV- but the PLC comms had been changed from default. I guess that it was done when the first PV failed (blank screen) and local investigations started.
This is admittedly a pretty obscure problem, but maybe someone else has run into it, or at least something similar. For reasons I won't get into...
141
Hello all, I have the misfortune of needing to support some old firmware version 1756 controllogix machines in rslogix 5000, as well as some...
986
Good Morning , I have a customer that has an old Panelview and an obsolete 1769-L35E processer . I need to replace the HMI , and I'm changing...
1,153
Hi, I have same system connected to 2 PC's running RSView32 SE (old)and another with Factorytalk SE (new). I next few months old one will be...
1,516
Doing some consulting work using factorytalk view studio and RSLogix5000. We set up alarms for the system a while ago and they work fine, as do...
3,649
