New to panel view programing Help
joeparrish
Nov 2007
owensboro ky
161
Ok I am using panel builder 32 and a allen bradley panel view 550.
I Put a momentary push button to run a blade forward. I want this to light up when the blade is forward how do I do that?
Use an indicator tag and reference to the bit that’s on that runs the saw is running forward
[font='Calibri','sans-serif']For example the push button is saw run forward b3:0/0 that turns on bit b3:0/1 in the plc program that start the saw forward use b3:0/1 in the panel view program and call it something like saw run forward indicator in the global object properties of you push button there is a indicator tag box this is where you would enter in your new tag you created for you indicator. [/font]hope this makes sense.
In addition to what Magic Smoke said, you will want to look at the STATES tab of the button properties and give each STATE of your indicator tag a unique appearance.
Paul
which softwer we r use for ab c600 panel view! also how can communication with micro logix 1400 slc via ethernet? i have rs view studio me...
14,064
Hi I am changeing the program in a 550 allein bradley panelview it is a touch screen with no keypad I need to change a timer in an allen...
2,915
I have a German programed ME program. I want to know what tag in the PLC a latched button turns on. However when I open up the tag properties I...
230
Am asking if we can upgrade sd ram and cf card of panel view plus ab by a normal sd ram and cf card but Allen Bradley to save cost because in ab...
297
I can't seem to get the Panel View Plus 7 standard edition to downgrade to V_11, when I check the AB downloads and compatibility websites for this...
145
