New to RSLogix500..
Preeya
Nov 2003
112
Hi everyone,
I am fairly new to RSlogix 500 but am pretty familiar with Siemens Step7 and ladder logic in general. I installed the RSlogix software on my machine. But at present I don't have the license key. I might get it in a week or so.
In the meantime, I want to know if there are any manuals available on the internet that can help me get started. I know there would be online help on the software but I cannot open that either as I do not have the key.
I would really appreciate any guidance.
Thanks!
I searched this site and found this..
Link
This is exactly what I was looking for.. I should have searched first before posting my msg. :)
silver platter department ...
these two are probably the best place to start ...
RSLogix 500 Getting Results Guide
SLC-500 Instruction Set Reference Manual
incidentally ... you didn't say what hardware platform you'll be using ... if it's not SLC-500 you might need a different Instruction Set Reference Manual ... there are a few differences between SLC and MicroLogix, etc. ...
Three things to try:
1) Go to THE ROCKWELL WEBSITE and follow the links for Documentation|Online Manuals| Control Processors. You'll want the SLC 500 instruction manual. (HERE'S direct link, but I believe you have to register first before it will let you there)
2) Go TheLearningPit. They have a simulator (with free trial) that you can download that is based on RSLogix500. You can play with that a bit to get familiar with the system.
3) Uninstall your copy of RSLogix and download the free one that will only work with a Micrologix 1000. It's pretty much the same software, but with limited features.
I'm surprised you can't install the HELP. That doesn't make sense.
284
So here's my situation, I have been tasked with modifying the logic to mimic a button press in the PLC. I have two identical machines however one...
556
Hello, I'm new to programming. I'm using RSLogix500 to modify an existing program for a SLC500. My plan was to use one of the existing inputs...
26
2,029
So i have an allen bradley rack (2080-LC50-24QWB), i have it connected through ethernet. I dont have an offline program so im trying to upload...
706
Hi Everyone, I am supporting a system which runs on a SLC 500 (1747-L532). A fault has developed whereby the output state of some digital outputs...
1,025
