New to S7 400 H cpu's
Plc_User
Dec 2005
Belgium
317
In a machine that contains a 414 H cpu in redundancy mode, I have to add 4 TP177 Mobile panels on the profibus network.
I have never worked with H cpu's before.
I will have to download parts of the changed program and also the hardware configuration (only because I added the panels and to make sure that the Profibus parameters are correct for the new configuration).
I doubt about the consistency of the hardware in my offline project, so I plan to upload the whole cpu, make changes in the hardware in that upload and download again.
Is uploading and downloading just the same as with a normal (not H cpu)? Do I do everything with the master cpu and do I not have to care about the slave cpu?
What are possible pitfalls? What should you be carefull when working with H-cpu's?
Does someone know a short instruction manual for working with H-cpu's?
Thanks.
I can't replace cpu S400 416-3XR05-0AB0 BY 416-3ER05-0AB0 in PCS7 Project when using replace object to keep the original configuration in the...
1,506
Hi All, I have a project that lets me control a Movimot drive via Profibus DP. A quick search on google learned me that a lot of information...
2,703
Dear Experts, We are currently in a project commissioning stage now of a Biomass Plant. The above mentioned CPU is used. 2 days ago, our load...
2,618
Hi, does anyone knows what is the problem on an S7-400 cpu in case all the leds are constantly on (not blinking, I think in this case it that...
7,217
I want to replace the exisitng CPU card of our S7 plc with spare card of similar type. Is it as simple as just remove old one after switching off...
1,535
