NMEA Protocol Datatype
Vaitheeswaran
May 2019
Madurai
20
Hello,
I am using Trimble 2000 GPS, I had been trying to take the Latitude and Longitude data in my controller and SCADA. I took position data from GLL package using Functional Block Diagram(Isagraf Software). But I need to show the data in SCADA(Wonderware Intouch). The GLL package data will be like "$GPGLL,3723.2475,N,12158.3416,W,161229.487,A,A*41" this. Here i need to take both 3723.2475,N and 12158.3416,W through modbus address in SCADA. I need to know what's the datatype of the values 3723.2475 and 12158.3416, is it ASCII or Decimal. When i tried to get these values in Wonderware Intouch it's showing a complete different value. If these data's are ASCII could you please tell me if Wonderware intouch can read/get ASCII values?
Thanks and Regards,
Vaithees :)
India.
Having worked with NMEA a lot I can tell you that you need to treat it as a string the number is actually 2 pieces of data which you will here sailors refer to as hours and minutes of longitude and hours of minutes as latitude. You can parse out as individual strings or make the whole thing a string. strings are stored in Modbus registers as bytes so there are two characters stored per register.
Hey Fred,
I had already did that, i took degree, minute, direction(North/South or East/West) as a separate string. Look at the attached image i had mentioned the each and every thing. In the N/S and E/W it should be shown as a string it shows as 306.00000000 for both and for the Latitude and Longitude the Degrees, Minutes and the whole data should be like 37°23.2475,N but its showing values like 818.00000000, 1586.00000000, 1074.00000000. Please help me with this.
Unfortunately I am not a Wonderware Expert but if you are parsing the output into string variables then it should display as string variables unless the objects you are using to display the data in on the screen are converting them to a number/float.
Are those digital display objects or smart objects?
See of there is a property that can force them to display string/ascii data only.
Hi, Im currently working on a project where I have to send alarms over to a VDR. The protocol is NMEA 0183 so the format should be NMEA. What i...
3,899
This thread is a continuation under a new title of an application thread regarding the interface between a Garmin GPS and a MicroLogix 1400...
7,267
well this might not be the site to talk about this but i would like to know if anyone has used this nmea 2000 communiction network before. I am a...
1,384
Hi Everyone, I'm wondering if anyone has successfully connected some NMEA 2000 equipment to a Modicon Quantum PLC. I've read that the NMEA...
2,546
Hi all Trying to remotely connect to a TIA Portal PLC. I can ping it without a problem but can't get my software to connect. I've opened port...
340
