No outputs working
alhughes
Dec 2010
Tasmania
Hi I have downloaded a small program to an existing plc5/05, while online the inputs can be seen to be working but the outputs both external and internal are not going true??
Any suggestions
Alan
Any suggestions
Alan
I know it seems obvious, but is the PLC in RUN Mode? There are other things that can cause problems, but usually just with I/O Cards. If you can't resolve it, post your RSP File (Zip it first), and we can poke around and sort it out for you.
Stu....
Thanks for the answers, the sub routine for that section had been deleted, put the rung back in and all good.
Cheers
Alan
Im on site, there was water damage in the cabinet. Trying to see what i can do Right now here is there. I can see all inputs, and LEDs work...
2,585
Hi All, I've been using AB PLCs for many years but this my first Omron project. I'm using a CP1L with the CX programming software and I can not...
1,985
Hello, I am trying to use the pulse outputs to control an external servo or stepper drive that accepts pulse and direction inputs from the PLC...
2,000
Hi All, Newbie questions but I have two of them!: 1. I am unable to toggle the bit on I:0 (it keeps at 0). If I go into the data file and...
2,466
I have a program with 2 ladders, one working and the other not so much. The outputs in ladder 3 will not turn on via software..the input logic is...
2,003
