NOCTI Test question
russrmartin
Aug 2002
Eastman, Wisconsin
744
My boss just gave some prospects the NOCTI test. One of the questions was something like this. When working with IC(integrated circuits?), which components are most likely to be susceptible to damage by static electricity? The options were CMOS, TTL, ECL? and BJT. Anyone know this. He has asked everyone in our plant engineering department without a certain answer.
Russ
First and foremost any of them could be susceptible to ESD, it just depends. In the past CMOS was the most susceptible of those mentioned but the advances in construction/design has eliminated a major portion of that susceptibility.
www.wikipedia.org offers an explanation for each device you mentioned, just enter the abbreviations and it will lead to each.
elevmike said:
Ron,
While your post is correct, the correct answer for the purposes of the test would be CMOS.
Maybe I did not make myself clear. I know the answer "looked for" would be CMOS.
BUT
Like many of these type questions it is outdated, the construction/design of CMOS devices has made them no more susceptible to ESD than most other devices.
If it was a written test and those were the choices I would choose CMOS BUT if it was asked orally then I would state that in the past CMOS was the most susceptible but that today that it is not. As I mentioned any electronic component is susceptible to ESD depending on the situation.
You made yourself clear...I was just clarifying your already clear and correct response...
I'm just one of thoes guys who keeps polishing and polishing...so never mind me.
Hi, I am using M221 reading from 3 different sensors (modbus rs485) sharing same bus (daisy chain). I am currently using READ_VAR (in total...
89
I am trying motor startup with pf525 drive by using wizard start over ethernet communication but during direction test it's showing control error...
192
See code at the bottom. Hi all. For the story, this is my first complete project using a Rockwell PLC, I've been mostly working with Unity Pro...
802
My question is regarding the number of Test outputs vs the number of inputs in a module. In the case of a 1734-IB8S card, there are 4 test...
1,204
Hi, I have to test a control logic that required to change the input temperature as the process variable from thermocouple transmitter on the...
628
