johnnysparks24
- Join Date
- May 2004
- Posts
- 54
Hello,
I have a SLC 500 5/03 processor and a 2711-B5A2 PanelView 550.
I have been sucsessful in uploading a existing application and downloading a new application. Everything seems to be fuctioning ok in RSLinx Gatway, its able to pick up the PV and processor just fine.
I can also (at times) use a analog input device and the PV reads the variation scaled value.
I keep getting a flashing messsage at the top of the PV that says:
required node (s) not found
If Linx is seeing the PV and the Processor and the processor is actually connected through the PV how could there not be nodes found?
If I unplug the cable from the PC then I can at least activate the touch cells but it still flashes the message. I must be missing something.
Thanks for any suggestions John
