JohnnyQuanex
Hello,
I'm trying to hook up an Elovis non-contact encoder to my 1769-L27ERM-QBFC1B controller...
I have the high speed counter embedded module, but seeing as this is not Allen Bradley gear I'm a little stuck on how to wire it up...
I've been using an Ethernet IP 842E AB encoder, but am finding it might not fit my application...
That unit was obviously plug and play and was easy to use...
I've attached images of the different configurations available for the Elovis and I attached the module I/O pin layout for the CL controller...
The Elovis uses numbers and the CL uses letters so I'm stuck...
Any help would be much appreciated...
Thanks,
John Whited
Thanks,
John Whited
