Non-Contact Encoder...
JohnnyQuanex
Nov 2015
Cambridge, Ohio
120
Hello,
I'm trying to hook up an Elovis non-contact encoder to my 1769-L27ERM-QBFC1B controller...
I have the high speed counter embedded module, but seeing as this is not Allen Bradley gear I'm a little stuck on how to wire it up...
I've been using an Ethernet IP 842E AB encoder, but am finding it might not fit my application...
That unit was obviously plug and play and was easy to use...
I've attached images of the different configurations available for the Elovis and I attached the module I/O pin layout for the CL controller...
The Elovis uses numbers and the CL uses letters so I'm stuck...
Any help would be much appreciated...
Thanks,
John Whited
Image on HSC module on L27.JPG Differential 5V ELOVIS.jpg Differential 24V ELOVIS.jpg Single Ended 5V ELOVIS.jpg Single Ended 24V ELOVIS.jpg
Differential inputs:
ELOVIS ---- HSC L27
I/01+ --- A0+
I/01- --- A01-
I/02+--- B0+
I/02- --- B0-
I/03+ --- Z0+
I/03- --- Z0-
Hope this helps you out.
Regards,
24V or 5V - It looks like it will take both. I would go with the 24V because you probably have this in the panel already.
I need to replace the measuring wheel of a cutting system. Problem is that I do not have enough space in the machine and the cutting process is so...
2,140
We have a customer asking us to measure the temperature of a moving chrome covered roll that is near room temperature. We aren't allowed to paint...
2,428
Good afternoon, I have an application where we induction harden different areas on our assembly part using coils that wrap around and heat up to...
3,749
Anyone out there have experience with non-contact length measurement? If so, please share your successes and lessons learned. I am looking for a...
2,298
We've had an intermittent issue with this for years. The application is sensing a level, or more accurately the absence of level in smallish ~5-10...
7,465
