non plc valve driver question
dougpdf
Feb 2014
kentucky
48
Hi guys
I'm going to show my ignorance here...but I'm hoping someone here can help.
I've got a late 80's Toshiba inj molder with a valve drivers (amps) built into the controls. One for pressure and one for flow.
They should send 0-300MA to a proportional valve, but even with the control panel set at 0, it won't go below 50MA. (there's an analog gage on the panel) so the pressure will only go down to 400 PSI or so. I would like it go down to at least 200psi..
I've looked the cards over for a trim pot, without luck.
I'll probably never need full pressure, so I was hoping I could put in a resistor or something between the amp and valve to reduce the current the valve sees.
Would this accomplish my goal?
Thanks guys
I will depend on the valve. Many valves hava a minimum setting you cannot go below.
I would try to do a test with a driver that can go to a lower current (or a power supply with current limit works for this as well) and see if I could control pressure in the range I wanted. If it works then go ahead and design the permanent circuit.
I am looking for some help with a project that I am working on to finish my maintenance apprenticeship. Any help would be greatly appreciated. My...
3,297
What he have is a HMI2GO unit ( KTP900F) and we use a safety relay to trigger our e-stops. What the tech wants to do is guard against e-Stop on...
1,869
(Allen Bradley PLC)Issue resolved by download the project, But What is the main root cause of this Major Fault Error code 62 “Non-Recoverable...
3,240
I wonder if it is possible to run a stepper motor in a non nc Plc? I have Heard that it is possible, just can't find any info about it.
2,031
Hey Everyone, I am hoping that someone out there could help me get a program loaded onto my GE Fanuc Series 90-30 PLC. Here is where it gets...
2,845
