allscott said:Me too, all the induction heaters I've worked with generally run in the khz or MHZ range.
60Hz induction heating is used, but it's not as common as the higher frequency. 60Hz is used more often when you are wanting to do bulk heating (such as billet heating). Higher frequencies are used more often when you want to selectively heat the skin of the part. The depth at which the heat is generated is inversly related to the frequency of the power.
Some examples of low frequency applications:
http://www.inductoheat.com/induction-low-frequency-heating-applications.php
As a side note, I have seen an ad for a machine that used DC power to inductively heat billets. The DC was used to setup a magnetic field in a superconducting coil (cooled with Liquid Nitrogen) and they rotated the billet in the coil. Pretty cool, and they claimed it was more efficient than regular induction heating.
Edit: I do agree with the others though; resistance heating would be much more typical for a plastic extrusion application. To the OP, what are you using to control the power to the heaters? Some controllers have the capability to monitor the balance of the three phase current.
Brian
