Not able to work with TIA Portal V12 Sp1
vivekavrsn
Mar 2015
While opening a saved HMI project (zap12) , i am getting a msg from TIA as ,
YOU CANNOT WORK FULLY WITH 'PROJECT' BECAUSE NECESSARY PRODUCTS ARE MISSING.
PLEASE USE APPROPRIATE VERSION OF TIA V12 SP1
PRODUCT : WINCC COMFORT SP1.
But Wincc is integrally got installed already :confused:.,
pls suggest me how to resolve this issue.
Hi everybody, I have this variable (Activate1) that should be set when I activate a button from the hmi, but instead is only set as long as the...
1,236
Hello, In Tia Portal I put a motion block called MC-MoveRelative from the Technology instruction. I choose an instance datablock and I want to...
1,454
Hi everyone. I am very new to TIA Portal, and I come mostly from the Rockwell world. I have a question regarding program structure. For some...
3,543
This is what I have: However, I cannot add an overlay i.e. an AT ... in the data type. There is a description of how to use the AT keyword in...
2,136
In my FC I use an inout variable for the memory of a Set/reset. When i call the FC i have the pin at the entry side of the block while i would...
1,936
