Should I be able use the AT keyword in TIA Portal
drbitboy
Dec 2019
Rochester, NY
8,099
This is what I have:
However, I cannot add an overlay i.e. an AT ... in the data type. There is a description of how to use the AT keyword in the help that comes with my TIA portal.
What am I missing?
TIA
Brian Carcich
Block must be set for non-optimised access.
Thanks for the reply.
Yah, I am sure it is something silly* I overlooked, but it's not that (I am pretty sure I unchecked that box before the OP).
* It is Siemens after all, and they want to be as silly as A-B, only they add unneeded complexity to try to hide it.
P.S. there are only two auto-complete results when I type "A" in [Data Type] cell, and neither is "AT" as predicted by the help file.
1. Have you compiled the block since de-optimizing? Try that.
2. Try collapsing The_reals before adding the AT
3. Delete the row, add a new one in its place, and try selecting the data type before entering the tag name.
Thanks for the ideas ...
1. Yes, no change
2. Done, no change
3. Done, no change
Perhaps my TIA Portal (V14) predates AT functionality?
I started a project from scratch, created the DB, made it standard (not optimized) access, compiled both [Software (Rebuild all)] and [Software (Rebuild all blocks)], added the Real Array and collapsed its row, deleted the (empty) row, and this was the result:
Last night I was trying to revive an old derelict machine after a slumber of many years. I couldn't connect to it with 1747-UIC cable from...
2,133
Hi, I am working on automating an industrial fabric shrinkage tester to replace its outdated electronics with a PLC. To get the tank's water level...
611
In a control System, I need to move 3 motors attached to roller in stages with speed of 1 to 2 RPM and the torque of motor should be 8-10 Nm...
832
Hi, I want to build a production line project using a PLC. This is the project page...
2,232
See picture. I want to add a rung (magenta) into the existing code. Can't figure out how to do this. I select a -||- , right? When I drag/drop...
21
1,809
