Numbers of motors on single VFD
Just another 2 pence input.
I deal heavily in siemens drives. As has already been stated, avoid starting multiple motors separately, as you will put full load start up current on the drive an cause issue.
In my scenarios I use different DDC sets (read parameters) based on how many motors an operator selects to start. I can then use this to program the drive with FLC etc.. more suitable for the combined load.
There is a specific parameter for number of motors in parallel, which also tunes the drive for dealing with inrush current on multiple motors.
Not all motors are made the same. While a four pole motor (at 50Hz) has a nameplate speed of somewhere approaching 1500rpm, they're all slightly different. I was just looking at two motors on our test bench yesterday and one is 1380rpm, the other is 1420rpm.
There's also the possibility of using a two pole motor which would be twice the speed for example.
Thank you Puddle.
In a PV 5310, can you format a numeric object to create comma's in the thousands position? I see no way from the properties panel.
454
Hello everyone, friends. I need help with something. I want to read and change Bit and Byte numbers via HMI. I found a code snippet for this as...
18
3,035
I'm working with a ROC800 program offline right now. Normally, you can switch your TLP view between text and numbers by making your choice under...
850
I can't say I recall ever encountering this, but when adding a decimal number to a REAL, I'm getting a strange precision. For example, starting...
1,471
Hello everyone, my name is Mick and I'm a beginner PLC programmer I'm using an Omron CP1L and a NS5 HMI and what I trying to to do is calculate...
1,233
