OkiePC
Your Micrologix serial port can connect to the DH485 network directly because its CH0 has DH485 with isolation built in. Use cable 1763-NC01 to go from the mini-din connector on the ML1100 to the phoenix connector that can connect to your DH485 cabling.
Then the DH485 cable will connect to each of the DH485 ports on two NET-AIC modules which each will connect to the PanelViews.
The PV will connect from its serial port to the NET-AIC.
The NET-AIC DH485 phoenix connectors are daisy chained together with belden 9842 or 3106A cable.
I am not certain that the PV Component serial pinout is the same as the panelview standard, so I am not sure which cables to recommend.
Hope this helps,
Paul
Hope this helps,
Paul
