PV+ 600 with external numeric keypad
Oct 2008
Perth, Western Australia
Hi all,
Long time member and lurker.
I am using an older PV+600 Touch (2711PT6C20D) programmed using RSView Studio 4.00.00 (CPR7).
Although old, this hardware/software combination has proved to be reliable since installation 10 years ago and the project has been updated many times without issues.
In use, the operators enter data on a table set up from a grid of Numeric Input Enable fields. A Numeric Display under each fields displays the current value of the tag being written too. I've included a screen shot to illustrate.
To protect this older hardware, I am currently using an external USB numeric keypad to save touch screen wear and tear associated with the popup keypad.
This all works with no problems.
What I would like to do is allow the operator to navigate between the Numeric Input Enable fields (i.e. move the focus) using the external numeric keypad cursor keys. Is this possible?
With a full USB Qwerty keyboard attached, the Tab key moves the focus between the Numeric Input Enable fields, but I can't find any other key that will do this.
Is it possible to assign behavior for specific external USB keyboard keys?
Is there a setting I'm missing that would allow the cursor keys on the external keypad to function this way?
Note that"Key Navigation" and "Take focus on press" options are enabled in the Numeric Input Enable fields and I've proved that I can move focus using the Tab key.
Any advice greatly appreciated (other than "go buy more up-to-date hardware" please!)
In case anybody ever wants to know, a solution was achieved using a Cherry G84-4700 programmable keypad: https://www.cherry-world.com/cherry-g84-4700-keypad.html
This device can be configured to store individual key presses and multiple key macros for each key. The configuration is stored in the key pad, so there is no issue with power loss and no need to modify the application. It is programmed using an old PS2 keyboard and connected to the PVplus using a PS2 to USB adaptor.
Hello, I have a set of three tanks with their own trio of Hardy 6600 series load cells. Two of them have no issues with where they are at and...
162
Can anyone recommend a flexible 600-volt shielded ethernet patch cable? I have used them from Allen Bradley / Panduit before and they are too...
112
Hi all, Im stuck trying to support a client with Motorola ACE.. I was able to upload all of the other sites to STS but one. Im working remotely...
120
I am trying to go to a 504 CPU. and on my hmi I am getting a 9028 error. can someone explain what they mean by change reference?
229
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
478
