Clay B.
swhite65 said:Be careful with extruders. The motors are sized for those cases that you mentioned. Otherwise, they usually run well under the rated load of the motor. This caused a lot of problems with brushwear where I was an engineer for several years. The brushes being used were rated for a current density that matched the nameplate of the motor. Due to running less than 50% of rated load, this caused the brushwear to greatly accelerate adding a lot of expense in brush replacement not to mention the carbon dust storms created during PM's. A DC motor can handle a hefty overload on top of its continuous rating. So I hope the 150 hp doesn't leave you in a "bind" should the plastic harden in the barrel.
Also, I guess the field was not a dual voltage field which would have helped the current capacity dilemma of the field regulator.
We had the same results here. We had an old Impco (think thats how you spell it) and the original motor went south. We had some smaller series wound motors for another aplication that were lower HP. What we ran into was excessive brush wear. I slowed down the accel curve to help reduce this some. We finally matched the motor to another brand with the same the orginal HP and this corrected the brush problem. Then we got rid of the old clunker.
I am surprised though. I would never think of starting an extruder with cold plastic in it. Replacing a screw is a nightmare. On several of our machines we would have to pull the entire barrel down to get enough room to get the screw out. You can not even purge on our machines unless temp is up.
