obsolete AllenBradley encoder cable
lesmar96
May 2017
PA
520
I don't do much in the Allen Bradley world. I have a customer that has some old Allen Bradley hardware. The encoder cable got ruined and it seems there is no replacement available anywhere.
any suggestions? p/n is 9101-1366-010
or if I could get a pinout for this cable, we could probably make one to get that back up and running.
Much appreciated.
-lesmar96
Why not make you own cable
I would assume the connector is still usable i have made many of them over the years
Icom should have the cable ou need or there ar many other sources.
most encoder would use 10 cond 5 shielded tuisted pare it not tht diffacult
In the old days we nearly always made our own
Thanks for that! but I had called them yesterday and they said they did not have it in stock.
That's the problem with Radwell. They like their website to show that they have absolutely everything you can imagine, but in reality, they might have a contact or a good source and a price for you, but no real parts to back that up. I have used them a couple of times with good results, and have been told, "sorry, we can't actually get that for you" once.
the number of wires in the cable should no be a problem
you can always find a cable
if you have a connections diagram or at least a pinout
nobody stocks much of anything anymore
Is then connector any good or do you need to replace it
we do have a connection diagram and yes we will make our own because we can buy the connectors. I did find the OEM apparently still has them but I am waiting on confirmation.
Would anyone happen to know anything about a HMI with model number HMI8D000L2P. It appears to be made by GE/FANUC/Total Control, but i can't find...
1,444
I am using an mpl-b220t-vj44aa on an older machine. Does anyone know if I can replace it with an mpl-b220t-vj74aa? The mpl-b220t-vj74aa is...
1,065
Good morning, Recently, I've heard the Micrologix 1500 PLC has become obsolete and Allen Bradley does not repair them either. Is there a list...
2,584
Hello in a factory uses a allen brdaley servomotor and controller which became obsolete , I want to know the criteria for the choice of a new...
1,593
I am converting a program from RSLogix 500 to 5000 in order to upgrade from SLC 5/04 to CompactLogix. From all of the information I can find, IIM...
3,114
