Obsolete servo motor.
furqanisar
Aug 2009
karachi
I am using a servo motor (Cat# 1326AB-B740 C-21) with Servo controller(Cat# 1394C-SJT10-T-RL) and Axis module (Cat# 1394C-AM75-IH).
What is the replacement of servo motor now that can be use with installed servo controller and Axis module? Old motor got obsoleted.
Anyone will be appreciated on guiding me. šŸ™ƒ
Regards,
FURQAN
I believe you can use the MPM range of motors, but you need to set up a custom motor in GML, sio if you do go down the path of using the MPM motor make sure you get the 11 parameters that you will need to program into the servo drive.
Alan
Alan
Thanks Alan,
Would I change only motor setup or need to change the GML program also.
Furqan
You need to program the 11 motor parameters at the start of the program, so that the 1394 knows the motor parameters, it is all in the 1394 manual, which parameters and how to do the programming.
Alan
1394c-sjt-10-t-rl
Alan
Can I use a 1394C-SJT10-T-RL controller in place of a 1394C-SJT05-T-RL, if everything else remains the same?
Where can I purchase a 1394C-SJT05-T-RL controller?
Alan
Thanks Alan,
Supplier quote me MPM-B2154E-2J72AA motor against 1326AB-B740 C-21. Is it the best replacement? Please guide me.
Regards,
Furqan
Regards,
Furqan
I am using an mpl-b220t-vj44aa on an older machine. Does anyone know if I can replace it with an mpl-b220t-vj74aa? The mpl-b220t-vj74aa is...
1,072
I don't do much in the Allen Bradley world. I have a customer that has some old Allen Bradley hardware. The encoder cable got ruined and it seems...
3,083
Would anyone happen to know anything about a HMI with model number HMI8D000L2P. It appears to be made by GE/FANUC/Total Control, but i can't find...
1,455
Good morning, Recently, I've heard the Micrologix 1500 PLC has become obsolete and Allen Bradley does not repair them either. Is there a list...
2,598
Hello in a factory uses a allen brdaley servomotor and controller which became obsolete , I want to know the criteria for the choice of a new...
1,597
