I wish I hadn't mentioned anything about the wireless AP. It really isn't very relevant. I would like a much smaller focus.
An earlier post made the analogy to a phone and a dial tone.
I know it was analogy and not to be taken literally, but to continue on with that analogy ...
specifically , what is happening when I connect my laptop to nothing else but a single panelview that causes the laptop to display that the network is connected and at what speed, and sometimes says "limited or no connectivity " sometimes not.
It knows that it is connected because the wire has a signal on it. They physical layer transport doesn't know anything at all about IP addresses, or how to route traffic, it only knows that there is a transmitter/receiver pair at the other end of the wire.
How does it know how much connectivity there is?
Limited connectivity is a message from Windows telling you that there is no known DHCP partner out there to assign you an IP address, and you have your IP Configuration set for automatic addressing (DHCP). In that case, by default, this activates the "APIPA" mode in Windows, and assigns an Automatic Privite IP Address in the 169.x.x.x range.
[/quote]
How does it know I can't connect to the internet through the panelview?
Possibly because the panelview doesn't respond when something is sent to the Gateway address? A PanelView isn't a gateway, and it doesn't handle DNS operations. Any time you try to access an address that isn't on your local network and subnet, the request is forwarded to the gateway address. It is up to the gateway router to handle sending the request up to the higher level network.
I would just like to know what the laptop is "saying" to, and hearing from the panelview, and yet gives me such a hard time talking to it until I discover and enter a compatible IP address.... which is often not an easy thing to discover.
Get used to it. If you don't know the address, you can't talk to the device. If you don't know the address, you can't mail a letter. If you don't know the John's phone number, you can't place a call to him. What exactly is so difficult to understand? A network isn't a point to point connection like (most) RS-232 serial connections are.
Forget Ethernet, you still need to know the node addresses for every other network out there if you want to use them, ControlNet, Profibus, Modbus...and many others.
Why not start reading up on some of the basics first, and then come back with questions?
http://www2.cit.cornell.edu/computer/support/subsubnetting.html
http://en.wikipedia.org/wiki/IPv4
http://www.howstuffworks.com/internet/basics/question549.htm
