OCMC - MBTCP - Syntax for a bit in a Word
dalporto
Jun 2021
Montreal, QC
258
Hi.
I'm struggling over some basic stuff here.
41001 I is a 16 bits integer that I'm able to read with InTouch.
What I need to do is to read each 16 bits individually, which I cannot accomplish so far.
Documentation I found lists it as 41001:1 (for bit 0). So I'm trying with two bits just to make sure that there is no offset at some point. Doesn't work, nothing is moving.
I tried 41001.1, don't work neither.
Since I can put about anything in OCMC and I don't get any error, it's all a big boring game of try and fail.
So, what is the proper syntax?
Problem could also come from the Modbus ProSoft configuration (read single / read multiple), and this is why I want to rule out the OCMC syntax first.
Thanks.
Hi, We have an application that has a device that goes through a reboot (appears un-graceful) What then happens is the MVI module appears to hang...
75
I'm trying to set up communications between a OI.MBTCP I/O server (for our historian) and a COMX510 that is on the same network , the COMX is also...
650
Hi Friends, I have an upcoming project were I need 20 pcs of ModBus TCP Clients / AOI. to control 10 devices I use 20 transactions to control 10...
743
Hi - I have a potential client who has a Wonderware / Aveva 2021 SCADA with the OI.MBTCP gateway installed. They want to get data out of their...
823
I am configuring the Prosoft PLX32-EIP-MBTCP module for control Logix and DCS communication but the configurations are giving me an error. Anyone...
1,019
