ODBC remote server setup for FTView
dowthebow
Aug 2014
Kildare
64
Hi, I have a previously set up system that logs Audit Trail, or Diagnostics to a remote historian server. There is no reference to the IP address of this remote server anywhere in the diagnostics setup.
I have to change the address of the remote server and do not want to lose the diagnostics database on the historian.
Where is the IP address or DNS for the Server stored?
Could it be set up as an ODBC source?
Open the ODBC Data Source Administrator(32 bit) (Type ODBC on the search box) and check for a System DSN.
Nick
P.S. You may need the 64bit version if it was setup as a 64bit DSN
any one know how to send data stored in an SQL Database over MQTT to OPC to a plant wide system,
2,635
Hi, I have same system connected to 2 PC's running RSView32 SE (old)and another with Factorytalk SE (new). I next few months old one will be...
1,513
Hi Everybody, I have created an HMI application on FT view SE 12.00. It has 5 tags and those tag values need to be backed up on database( ODBC)...
1,428
I'm using FTView SE to datalog to SQL Server with an ODBC connection. IS there a method to signal when this connection is broken for any reason...
1,166
Hello guys! Good day Everyone! We have a problem on the FTView Studio DataLog. I've created two different Bit of Data source (ODBC) which are the...
5,812
