Oil Flow Sensor Recommendation
The Plc Kid
Feb 2009
Macon, Georgia
3,233
I am looking for a OIl flow sensor to verify oil flow in a gearbox befor allowing the gearbox to run. So I am not really trying to measure the amount of flow but just verify that there is flow.
It would be nice to log the volume of flow and set a range based to the amount of flow. So a discrete or analog output would be work.
Give a little more information, Please...
I rarely post but often read....
Anyways; You aren't providing enough process information to intelligently specify a flow meter/switch. Tell us the flow rate range, viscosity, temperature, pressure, accuracy required, specific gravity, composition (solids or other characteristics) etc. and maybe you'll get a qualified specific solution. Geez!
I guess I'm a quiet "watcher" or "reader" of posts for a reason...LOL! But----tonight I'm having a few beers and couldn't resist weighing in on the, once again PLCS.NET, obvious postings...I see them all the time from Allen-Bradley, through Micro Motion to Endress+Hauser to Unitronics to OPTO 22 to Modbus to Laptop questions ad nauseam ...most of the time it's just a chuckle or a head shake but for some reason I felt compelled, this one time (probably the beer), to become more vocal. There are a lot of guys here that post in the 1000's of responses but end up in the "Yada, Yada, Yada..." category. Still amusing, but not that impressive...Anyways, I enjoy reviewing the trials and tribulations of everyone here and I DO learn things, here and there. :) Thanks Guys & Gals!!
Wow man sounds like you know everything.
Anyway I was not asking for anything that specific just a general recomendation of brand not specific model. RTFP.
How is the oil circulated? I did a couple of systems that each had variation on oil sensors. I don't like heavy oil and movable switches.
If is a light weight oil than a movable switch is OK.
I used a high pressure piston diaphragm to sense the oil pump was running on Med weight.
On heavy oil I used a Mass Flow Meter. It was overkill but we had it in stock.
Sounds to me he is pretty familiar with Rheology (Wiki has a good description) and asked you some very good basic design questions.
A non specific solution is to watch the lubricant come out of the pipe.
Dan Bentler
I have been looking for something as well. We had a 1600 hp pulp refiner go out because someone shut off the bearing oil supply. They had a pressure switch on the line but the valve was closed at the return. I have been looking for a few weeks and the thing that I came up with was most of the analog flow meters would not do temperature compensation so they would not be accurate. As the oil thins out the flow will change. I am aslo looking at adding a thermocouple to see if I can figure it out. Our local Motion industries guy came up with one that will so it but I dont lnow much about them. I will post the details on Monday when I get back to work.
you could read pressure to indicate flow, either static pressure or differential across an orifice.
One of the engineers has asked me to add code to the PLC to calculate oil flow rate based on delta pressure, using the equation below: Flow rate...
2,820
Hi everyone ! Im looking for a flowmeter to measure dirty soybean oil. Working temperature is around 80°C, pressure around 1,5bar , and...
2,466
The rosemount 8712 flow meter is displaying coi open circuit. Should iI just replace the sensor? I looked in the troubleshooting and only thing im...
4,789
Looking into using a PLC to control multiple solenoid liquid valves that control flow of oil through a piping system. The solenoids are energized...
3,210
Hello to all, is my first post on the forum, I searched everywhere, but I could not find an answer to this problem; I am quite experienced in...
994
