Old Allen bradley motherboard
Trazor
Sep 2023
Wisconsin
Hey everyone, I'm new and dealing with a Allen Bradley motherboard 006S107-05-013. The first power up it posted the video to a monitor i attached but gave a bios error but i had no keyboard control. did a reboot, then it would power on and the fan ramp to max speed but no video post. i feel like its a bios issues but after unplugging the main power and the cmos battery i'm still stuck at the same spot. and thoughts?
I tried pulling the ram and even swapped it with another PC we have for a different system but it would just ramp the cpu fan to max and no beeps or anything. I recalled many moons ago a issue that was somewhat the same on the on a friends PC i was working on and it was the power supply dying and not putting out the needed watts. i tried swapping in the power supply from the other PC and it worked, the board posted to the bios and when i hooked the hard drive back up it booted up like normal.
i thank you for the quick responds and for anyone else with this issue, check your power supply. lol
Just wanted to post a quick up date again for anyone with a old Allen Bradley motherboard out of a VersaView 1200P that might have a problem like i was having.
So the power supply replacement did get the unit to power on and post however it would only post after completely disconnecting main power letting the board sit for a ten plus seconds and hooking it up to power. otherwise if i turn it on then just did a normal shutdown and tried restarting it, it wouldn't post again.
Now i can say the system has been running all weekend without fail and what it ended up being along with the power supply was a capacitor. the bad capacitor was one that was by itself near the center of the board just down from the processor. it had a slight dome to it. the unit has been powered down and rebooted over 30 times and boots up every time now.
2,509
I have recently replaced an old Panelview with a new Panelview Plus 1000. It communicates with the old SLC PLC over a DH+ network. All the...
3,926
After working with Allen Bradley models since 1983, it can still be troublesome to remember which comm cable is needed for each different model of...
2,478
Good day all. I was sent to troubleshoot an old E-beam welder. It has an Allen-Bradley PLC I have never seen before. It is huge, by todays...
2,182
I want to connect three PLCs together. I have two SLC 5/03s. One with an available serial port, and one with an available DH485 port. And one...
4,077
