older TI 305 communication
tommy23t
Nov 2003
New Jersey
136
Does anyone have a pinout or know if a straight serial cable will work for programming on an older TI 305 plc? I have the model 305 03DM RS232 module that seems to work (lights go on). I was trying to do this with my laptop using Win 98, DOS window and DOS mode, no luck communicating (locked up). I am going to try again with DOS on an old laptop. The only software I have is TISOFT. It has been 12-13 yrs since I used this last, lots of cobwebs to clear. Any help is appreciated.
Thanks,
tommy23t
Thanks, Mike. I'll try that. I do have the directsoft32 that I thought supported this, but it only likes the 330 series (fine print). I could not come up with a link with that software at all. Maybe the cable is the same, worth a try.
thanks,
tommy23t
Keep in mind that although DirectSOFT can program similar products, it does not work with ALL. For example, although it can program the TI305 series, it will NOT work with the TI315xx series CPU.
For reference, here is a chart showing the non-DirectLOGIC products DirectSOFT32 can currently be used with:
[attachment]
beerchug
-Eric
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
481
Hello, I am trying to streamline an AOI that will get module/controller statuses from ethernet IO tree. Everythings fine, however, does anyone...
16
1,576
Hi, is there any way to export all contents of Block folder (OBs, FBs, DBs, etc) to a text file? I know it is possible to export symbol table, but...
1,245
I was looking at a Studio5000 PLC file as reference, and noticed the "standard" for this job used was using program tags for each program folder...
1,576
I'm looking for someone that may have a download file of TIA Portal V14 and 15. I have a customer that has 2 PLCs on is a 1212C with firmware 4.5...
3,341
