Omron and GE data Xfer
Most GE Fanuc PLC's can talk one of three dialects of TCP/IP. Which one of these is common to Omron?
A. GE Fanuc SRTP
B. GE Fanuc EGD
C. Modbus TCP/IP
D. Non of these
If D, you will need a translator (protocol converter).
Or, you may want to give us more details of your system.
Modbus
Omron is capable of Modbus TCP frame format. The software is new to me so I really do not understand what needs to be done to set it up. It would be a simple process if I was using two GE or two Omron PLCs but unfortunately, I don't have that option.
Our system is still in the development stage. We are bringing in a machine that has an Omron PLC to our facility and it will have to be interfaced with an existing GE Fanuc system. The GE system consist of a 90-70 series PLC with Genious blocks distributed throughout the process.
Dear colleagues, I've made a couple of projects with Omron PLCs, still, I can't figure out a quick solution to this one. I have a CJ2M-CPU32...
2,385
Hi Guys, I am trying to read data from Omron CP2E CPU from my Mitsubishi RJ71EN71 with Simple CPU Communication Function. Suppose it was using...
1,815
I'm working with a customer to copy one of the machines they designed in-house several years ago. The previous PLC programmer had a thing for...
2,093
I should back up the data in the Omron NT11S terminal to my computer, but is it possible? The company that supplied the hardware and software no...
1,492
Hey guys. I recently added a barcode scanner to our network. I can see the device through network configurator. When trying to set up the tag...
1,632
