Omron b7as-t6b1 and b7as-r6b31 modules
Killercal
Aug 2006
Ontario
150
Hello all,
A customer has asked us to connect Input/Output blocks to their CC-Link network and have supplied the above modules. I've never worked with these and after doing a quick search it looks like these are not CC-Link compatible.
Has anyone worked with these and can they confirm that they will not work on CC-Link.
No know anything regarding these?
The customer is saying they had these connected to CC-Link, but I'm not sure there are any switches to set an address, therefor not being able to work.
Any help would be appreciated.
Thanks.
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
178
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
70
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
111
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
267
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
147
