Omron CJ1G and CXprogrammer 3.1
Durhamgoat
Oct 2009
Jasper IN
Hello and I am new here and very much a plc novice.
I have an OMRON CJ1G-H CPU43. We have several of these plc’s in identical machines in the field and they work fine. We built a 3rd machine and I downloaded the program to it. Now I cannot work online with the program. I get a “failed to connect to the PLC” error and it suggests power supply, connection, network settings of change plc dialog and finally make sure device matches type.
I am using cx programmer 3.1 and if I open the programmer and just connect to the plc it does so and I can upload the program if I want, I have several times just to make sure.
So I believe that I have a good working cable and the plc is on.
Is there something I am missing?
I thought to erase the program in the PLC but don’t know how to do that. I could then try to establish communications and re download the program.
Help please.
Brent
Found it
It was a com port mismatch. The existing program required a specific com port and the empty porgram used what was available.
Thanks.
you can change that in the project tree on the left hand window goto the symbol for the processor right click it and yuo will see "change" this will allow you to select the comport you are currently using
Hi friends, Need to replace the Omron CJ1G series with the CJ2M. It is a Rack type PLC and CX programmer software is using for the Program...
2,342
Hello Guys, I removed an Omron CJ1G CPU44H CPU (leaving the I/O's on the din rail)with the intention of uploading the program. When I...
3,071
hi, i find new way to solve my problem. I find CJ1G-CPU42H to implement fuzzy logic.This PLC can solve problem in fuzzy but i must use CX-process...
1,710
Hi all, I have attached my code. I connect with PC via Peripheral, Unit 0 node 1 (192.168.55.1 )connect with DiGi Connectport TS W...
1,619
Hello. I am developing an add-on program for a existing Omron CJ1G CPU. The system consists of 1 CPU and 4 Remote IOs. The main rack input start...
7,276
