OMron CJ1m and CPM1
jairus
Aug 2010
Busay Cebu City
47
Hello there! i need some help regarding omron plc the CJ1M and CPM1, do they have the same software and connecting cable? and which of the two is the latest plc from omron? or which of the two plc is more advance?
thank you...
The CPM1 is a unit which is pretty much obsolete.
It is a block type PLC with limited expansion capabilities.
The CJ1M is a different animal altogether, it is modular
With many types of I/o modules and communications modules.
Both can be programmed using CX One.
The CJ1 is basically being replaced by the more advanced CJ2 - I have been using the CJ2 for quite some time now.
I understand that the CPM1 has been discontinued - no longer manufactured.
Thank you so much for all your reply. We had a cj1 here and i already edit some part of the program and the other is cpm1 guess i need to replace this with cj2 so i can expand I/O.
If you need a shoe box PLC the CP1L is pretty expandable - it may be enough. It is basically the replacement for the CPM1 and has virtually the same instruction set as the CJ2. It has the capability for serial cards and an Ethernet board (limited functions though). You can even add 2 x CJ1 cards to it. Worth a look.
Hi dear . I have a system with cj1m cpu11 etn. previously NT 5z HMI was connected with plc. recently my old HMI got damaged. I want to replace it...
252
hi dear all hope you all are fine I have a problem with my CJ1M cpu11 ETN. it stop communication with PC over ethernet. ETN unit all indications...
170
Hello everyone. I am new when it comes to Omron PLCs. Currently I'm uploading program from CJ1M PLC using CS1W-CIF31 cable only. I connected the...
163
i have been trying to connect to omron cj1m via peripheral port(USB to Serial), but there isn't any sign to show that it has connected, so am...
318
Has anyone encountered an error code 31 on an omron cj1m-cpu12? This error code is not covered in PLC manual.
522
