Omron CJ1M CPU11 ETN
ali1122turk
Sep 2022
home
hi dear all hope you all are fine
I have a problem with my CJ1M cpu11 ETN. it stop communication with PC over ethernet. ETN unit all indications are off, on cpu unit ERR/ALM flashes. when I restart cpu, problem resolved, but after half an hour again same issue.
please help me any one
If you cannot communicate via the ETN card then you likely have an I/O fault. You could try power down then reseat all modules including the power supply and terminating end cap.
thank you.
It did not comunicate unless I power down and restart all modules.
After restart it is ok. but after some time same happen again. should I have to replace some hardware?
Hi dear . I have a system with cj1m cpu11 etn. previously NT 5z HMI was connected with plc. recently my old HMI got damaged. I want to replace it...
316
Hello everyone. I am new when it comes to Omron PLCs. Currently I'm uploading program from CJ1M PLC using CS1W-CIF31 cable only. I connected the...
195
Hello, I have PLC Omron CJ1M/CPU11, the problem is whenever i connect the PLC to my PC (laptop) via serial port and try to go direct...
2,509
Hey, new to Omron. I have a CJ1M CPU11 PLC that I need to connect to and backup. When I look up Omron programming software, I find three different...
1,699
Hi everybody, I can't transfer data from laptop to omron sysmac cj1m cpu11. I use cable "omron cs1w-cn118" and Uport 1150 (RS232),I sure software...
3,931
