OMRON CJ1M writing to memory
eatunzo
Feb 2013
Ankara
I am relatively new to PLCs and very noob on Omron although I ended up trying to get one working.
I am trying to get my hioki measurement device to get hooked up with CJ1M-CPU22 via scu41-v1 (rs-232). When I start a send/receive sequence and trace the communication, I see that the value I am trying to receive is there but I when I transfer the data from my PLC, It seems it does not write the data where it is supposed to write. To identify the problem i added a 'set' function to the same rung. It seems although I see the bit set to 1 while monitoring, I cant seem to change it in the PLC. The bit is still 0.
I am attaching the files. I appreciate it if someone can help. It sure is a simple problem.
Best,
Tunzo
Hi dear . I have a system with cj1m cpu11 etn. previously NT 5z HMI was connected with plc. recently my old HMI got damaged. I want to replace it...
255
hi dear all hope you all are fine I have a problem with my CJ1M cpu11 ETN. it stop communication with PC over ethernet. ETN unit all indications...
171
Hello everyone. I am new when it comes to Omron PLCs. Currently I'm uploading program from CJ1M PLC using CS1W-CIF31 cable only. I connected the...
167
i have been trying to connect to omron cj1m via peripheral port(USB to Serial), but there isn't any sign to show that it has connected, so am...
323
Has anyone encountered an error code 31 on an omron cj1m-cpu12? This error code is not covered in PLC manual.
523
