Omron CP1E and Modbus RS485
I get what your trying to say now. Ok I guess some reading is ahead, so I can figure out how to read and move the address properly.
Ill keep everyone informed of where I go.
Thanks for the help so far
Something else to be careful of, is that 1 16 bit word from the slave may be spread over 2 words.
High byte of lower word, low byte of higher word.
Or, you may of worked that out already��
Hello! I have tried to communicate with a Danfoss drive Aqua FC301 over RS485 but I had no sucess! Attached you will find the demo project that...
4,292
Hello. I have a problem with omron sysmac cp1e controller delayed start. The controller has been working on the punch press since 2016. Recently...
762
Hi, I need to communicate omron CP1E PLC with SCADA to get the status of the machine. There is no etherent port available but an empty expansion...
1,601
Hello... I remove one CP1E from old useless machine and I would like to use it with something else....but it is locked/have no pass/....How can I...
1,445
hi all i have used a real time clock to turn on a bit after 1 month. the plc was off for this whole month and when i turned on the plc after a...
1,422
