Omron CP1E Compare =S
JoeTauser
Apr 2006
St. Louis, MO
17
I am new to Omron but have been programming different PLCs for a long time.
This problem is vexing me. I have read the help at least half a dozen times and I don't see what I'm doing wrong.
I'm using a CP1E and have the latest CX-One software.
I am using a =S block to enable code based on a pointer. It works in some places and not in others. I do get a warning that I have a duplicated output on the rungs where it's not working, but they are SET, RSET, and MOV commands. These should be OK, but there could be some rules in Omronland I don't know about.
I have attached the program. The problem is in the "HMI_Intfc" section. Any help or insight would be greatly appreciated.
Joe T.
You only posted the .opt file - not necessary - you need to post the .cxp file. The .opt file only holds info on how the program looked when you saved it.
I have never used this function before. That aside I would be inclined to take out the second RSET line and include it in the first RSET. I cannot think why but it may be causing an issue. I would also be inclined to use the ESTOP input direct.
Hope it helps but I have not used the function.
Bob-
Thanks for replying on this.
I finally figured it out through copying and pasting working logic from another part of the program. The Omron Help, while extensive, was really of no help at all. I literally spent hours combing through it and the detail I needed wasn't there.
See if you see it right away what I eventually realized-
Non-working:
Working:
Hello. I have a problem with omron sysmac cp1e controller delayed start. The controller has been working on the punch press since 2016. Recently...
766
Hi, I need to communicate omron CP1E PLC with SCADA to get the status of the machine. There is no etherent port available but an empty expansion...
1,612
Hello... I remove one CP1E from old useless machine and I would like to use it with something else....but it is locked/have no pass/....How can I...
1,451
hi all i have used a real time clock to turn on a bit after 1 month. the plc was off for this whole month and when i turned on the plc after a...
1,427
We had a CP1E go bad (power issue). Installed spare and could not get it to communicate to our motion drive via add on RS485 card. Tried...
1,509
