Omron CP1E - OPC
Koenh
Nov 2011
Flanders
Hello,
Does anyone has some experience with an opc server to an OMRON CP1E plc?
This plc has a USB programming port and a serial port to connect fe. an HMI panel.
I found this article
http://www.kepware.com/KEP_KB/?solu...licKnowledgeSolution/d?&id=50140000000RiWyCsY
which stated that this should work with a serial connection. But i have to point a COM port. I don't know how to point a COM port for a USB device.
To use the serial port, i don't know where to find any drivers.
Already thanks.
Tx for the replies.
Omron's own OPC server, maybe?
CX-OPC-Server
I just want to use a demo version since it is for testing. I don't find a demo version of the OmronSoftware.
I used an OPC Server for OMRON from MatrikonOPC ...
http://www.matrikonopc.com/opc-drive...r-details.aspx
With the matrikon, i don't find any drivers for the CP1 plc.
It has a usb port and a rs232 port.
the rs232 port is used for HMI, but i can temporarly change this setting
Can you please explain me how you did it?
Already thanks.
Someone have done the Matrikon OPC Server connection with OMRON CP1E by USB?
I am trying to do this for a long time, but I not found the solution.
Thanks for attention.
Koenh,
You may want to consider Kepware's KepserverEX. You can download a run time restricted version through our web site...
http://www.eternity-sales.com/Kepware/kepwaredownloads.htm
Also in this download section you can view the manuals for the drivers you will require.
There is no charge for the download, but keep in mind it times out after two hours of operation. Upon timeout, you can restart the server.
Disclosure - ESI is an authorized Kepware distributor.
Hello. I have a problem with omron sysmac cp1e controller delayed start. The controller has been working on the punch press since 2016. Recently...
762
Hi, I need to communicate omron CP1E PLC with SCADA to get the status of the machine. There is no etherent port available but an empty expansion...
1,601
Hello... I remove one CP1E from old useless machine and I would like to use it with something else....but it is locked/have no pass/....How can I...
1,445
hi all i have used a real time clock to turn on a bit after 1 month. the plc was off for this whole month and when i turned on the plc after a...
1,422
We had a CP1E go bad (power issue). Installed spare and could not get it to communicate to our motion drive via add on RS485 card. Tried...
1,494
