Hello,
I am trying to write a program for a freezer system. I have a CP1E with TS101 expansion for testing, but the actual project will use another CPU, not sure yet which one.
I have to control the temperature in 15 cooling warehouses with a single PLC. The warehouses are using shared ammonia compressors to obtain cold air. The temperature has to be precisely -22 degrees Celsius in each warehouses(+,- 0,5 degrees C). When the temperature goes above -21 degrees for more than 2 mins in one of the warehouses, the ammonia compressors start to work and a valve brings the cold air to the warehouse. When the temperature reached -22 degrees, the walve closes, and the compressors stop to work (unless they are needed to cool down another warehouse.) There will be a PT100 in each room
Since the temperature has to be very precise, I assume that I have to use PID control
I have never made any temperature or PID control before, so I need some light from you guys
I read the manual, but I need some more explanation to understand it.
If you could show me a sample program of a PID temperature control with some explanation, I would be very thankful .
