Omron CP1H ETHERNET CONNECTION
erivinoth
Jun 2011
pondy
29
HI,
Omron CP1H PLC able to Connect thirty party SCADA (Allen Bradley) via Optional Earthent Port. And can i use two port (Eathernet and Rs232c) in one CP1H CPU module. If any one knows please let me know.
Thanks,
Regards,
M.Vinothkumar
The CP1H will accept two option modules so you should be fine. There are some restrictions on the early CIF41v1 option modules but those were corrected in the CIF41v2. You will have to set the DIP switches properly and configure the option modules (serial ports 1& 2) in PLC Settings according to the instructions.
erivinoth, "Ethernet" is not enough to know. What communication protocol do you need on Ethernet?
FINS/TCP? Ethernet IP? Modbus? Socket service?
CP1H can take 2 optional communication boards on the main unit and 2 CJ1W modules on the side.
All may be communication modules, in almost any combinations, except 2 similar ethernet boards on the main unit.
CP1W-EIP61 board is an adapter(slave) for Ethernet/IP implicit messaging.
It does not need any configuration other than the port IP address, which is done from Internet Explorer or other browser.
For PLC to be Ethernet/IP scanner (master), or for explicit messaging, CJ1W-EIP21 module is required. It is configured via Network Configurator program from CX-One package.
Hi all, I have to say first that I have no experience with Omron devices, but here's the challenge that I'm facing. I have an Omron CP1H...
1,708
I have a question about SET instruction in Cx-programmer. When condition goes true it is supposed to give value 1. But, my controller is giving 0...
24
2,287
Hello Sir/Ma'am, Hope you and your family are safe in this Covin-19 Pandemic. One of my client have a machine in their ceramic industry which...
2,617
Hi, I recently had to buy a batch of new electrical components containing 10 PLC Omron Type (CP1H-X40DRA) Apparently stored in store (to be used...
3,542
Hi, i'm using cx programmer 9.5 running on my vmware and trying to connect to my CP1H- XA. I did the required driver installation suggested in the...
2,845
