Omron CP1L PLC + MAD11 Module Question
ajorge
Aug 2009
Portugal
Good afternoon to all!
I'm trying to develop an automatic system to acquire some data regarding voltage signals. But i'm having some problems because i don't know how to achieve this. I have a voltage probe connected to my analog module but i can't receive any kind of value from it. Is there any kind of step by step tutorial about this subject?
Thanks.
Yes,
1. GTM
2. RTM
3. Put what you have read into practice.
Do you have access to all the manuals for the CP1 range? It is all covered in there on what to do.
Hello, I have an installation with an omron plc CP1L with a CJ1W-CIF12 module connected to eight omron MX2 drivers. I use the bus to modify the...
2,156
Good afternoon, I need to create a recipes display on the hmi ns8, to change the parameters of a servo and some strings . The PLC that im using is...
2,776
I have a problem with my machine....we are using Omron CP1L PLC with a set of temperature controllers and Hakko HMI to control a set of 16...
2,346
In the hand position: Pumps 1 and 2 are controlled and alternated by the hand selector switch. When Hand position is first selected, pump 1...
3,604
Not able to connect to OMRON CP1L-EM PLC, I want to restore factory default ethernet address settings and port settings. Please suggest how can I...
2,276
