Omron CPM1A 30DR - Oscillator Circuit
kaminari
Aug 2003
I'm having a tough go at getting an oscillator (ladder logic) circuit I wrote in CX programmer to work correctly with my Omron CPM1A 30DR and I can assure you its operator error.
I've done these before in Hitachi and Allen Bradley PLCs before but even these circuits don't seem to work right in the CPM1A.
Does anyone know of resource of good programming examples of ocsillator cirsuits somewhere or suggestions on how to make a plain-jane ocsillator circuit?
Thank you,
kaminari
Please describe in better detail what you want by an oscillator circuit.
1. Flip-Flop?
2. Variable Speed?
3. Square Wave?
4. Faster than 10ms?
We do not understand your request.
here is the simplest one i can think of:
A A
you can do the same with the timer
(replace coil with timer block and then you
can control the clock speed)
note that in both cases you would get
one scan "spikes" as signal output which
is fine for counting etc. If you use the
timer and requre say 50/50 signal ratio,
you could divide it by two or use second
timer to get nearly symetric output.
The problem with the above designs is
that they are scan time dependant
and always slower that the scan.
In case you need clock faster than
scan time, you would have to setup an
interrupt routine.
I've got an upload from an Omron SYSMAC CPM1A PLC but I cannot figure out for the life of me how to document the inputs and outputs. It's version...
3,300
Hi, I have recently purchased an old Omron Cpm1a plc to practice on. I have a version of syswin that does not require a licence to program these...
1,666
I have a Omron PLC with CPM1A-MAD01 anaolog input output module its reading pt100 temperature probe. When the machine is running it starts to...
1,094
Hi, I have recently being using a Omron CPM1A-40CDR-D-V1 and transferred an old program on it. I was testing the program and making some...
4,252
I have two of the same units that are using a CPM1A and an NT20S-ST121B-EV3. I am not able to connect to the touch screen as far as i can tell via...
16
4,008
