Omron CPM1A and AD041
rgmiles
May 2006
Mountain ash
53
Hi all.
I am using cpm1a-ad041 analogue card with a CPM1A-30CDR-a-V1.
and a NT2S screen.
How do i scale the output of the ad041 to display in decimal on the screen?
The CpM 1a does not support the scale command.
Thanks in aticipation
Bob
You will need to do this the "old" way, using Multiply, Divide and you may need to Add an offset value.
I do not have an AD041 manual handy, and it may depend on which range you have set, but there will be a range of values that the unit will send to the cpu. Based on this range, you will need to calculate the scaling "multiplier" and offset values.
Proper choice of these values will give you the desired number to display on the NT2S.
Hope this will help.
I've got an upload from an Omron SYSMAC CPM1A PLC but I cannot figure out for the life of me how to document the inputs and outputs. It's version...
3,300
Hi, I have recently purchased an old Omron Cpm1a plc to practice on. I have a version of syswin that does not require a licence to program these...
1,669
I have a Omron PLC with CPM1A-MAD01 anaolog input output module its reading pt100 temperature probe. When the machine is running it starts to...
1,096
Hi, I have recently being using a Omron CPM1A-40CDR-D-V1 and transferred an old program on it. I was testing the program and making some...
4,252
I have two of the same units that are using a CPM1A and an NT20S-ST121B-EV3. I am not able to connect to the touch screen as far as i can tell via...
4,008
