OMRON CPM1A + TS101-DA+MAD11 Programming
DetlefP
Jan 2013
Michigan City
Hello
I have another question regarding OMRON-CPM1A programing especially with programing the analog expansion units. I have TS101-DA for temperature and MAD for analog I/O's.
I know I have to set at first a range, but I do not get it from the description in the manuals....
I am working with CX-Programmer version 9.3.
The trouble starts to do the right addressing....The TS101-DA unit is right behind the CPM1A-30CDR....so I guess the adress for the first temperature input starts with 2.00 since the last input on the CPM is 1.05....
could you give me an idea how to start to get temperature readings???? Can i use the out put on that unit for displaying the temperature on an external display????
And unfortunately I do not have a real clue how to programm the MAD11...has anybody a simple example were I can see how it works??
Can anyone help me out, would be great
Thanks a lot gtsuport.....
IU alreadfy figured out the corrtect addressing of the TS101-DA, found a datasheet in the forum.
Your link was a great help too...thanks a lot again..I keep you posted whether I could make it work....thanks
I've got an upload from an Omron SYSMAC CPM1A PLC but I cannot figure out for the life of me how to document the inputs and outputs. It's version...
3,325
Hi, I have recently purchased an old Omron Cpm1a plc to practice on. I have a version of syswin that does not require a licence to program these...
1,680
I have a Omron PLC with CPM1A-MAD01 anaolog input output module its reading pt100 temperature probe. When the machine is running it starts to...
1,106
Hi, I have recently being using a Omron CPM1A-40CDR-D-V1 and transferred an old program on it. I was testing the program and making some...
4,280
I have two of the same units that are using a CPM1A and an NT20S-ST121B-EV3. I am not able to connect to the touch screen as far as i can tell via...
4,026
