Omron Cpu Error
indra
Apr 2005
indonesia
161
I have CPU omron type C200H CPU01 and I want to replace with the spare C200HS CPU21 after save the original file then I replace CPU, switch on power but on the CPU C200HS, there is error message "I/O SET ERROR". Please inform me how to solve this problem. I have tried to reset via console ( CLR, FUN and MONTR ) but not succeed the error still remain.
Do I have to write down the I/O table first, on the old CPU ( C200H ) ? If yes, how I can replace on the new CPU C200HS ? I use the SYSMATE software Ver1.20
Please inform me how to do it as detail as possible.
Regards,
INDRA
Hello Indra,
Sounds like you need to create the IO table.
Don't know how you would do this using Sysmate software, but as it sounds as if you have a Procon, follow these steps...
FUN - SHIFT - CH/*DM - CHG - 9 - 7 - 1 - 3 - WRITE - 0
That should then create the IO table for you.
You may need to power-cycle the PLC after.
Hope this helps
Dear Experts, Good day:) This is the 1st time I work with Omron PLC, I have one machine operating with Omron sysmac cj2m cpu 31. The PLC has...
4,982
Hi Everybody, I am using Omron CS1H CPU in one of my project. There are five machines using same CPU, same program and same design ( meaning 5...
3,160
Hello Guys. I am having a problem with my omron cqm1h cpu 51 and i need help from you over there. The problem is that every time i power the...
6,988
I have a project to control the speed of motor DC using PWM Output on PLC and when im on working i have a several trouble and of of them is the...
248
Project involves updating a ~23 year old controller (C200HX CPU64). The HMI is a windows NT machine with the gui done with Delphi 5 (Pascal)...
1,117
