omron cqm1 getting online trouble
srummel
Jul 2011
TN
17
trying to get online with cqm1 cpu21 keeps getting failed to connect message. anyone have any ideas. I am using usb to serial converter to use the rs232 port
The RS232 port is not standard. you will need a special cable between the converter and the PLC RS232 port.
it is also not uncommon to have trouble with USB/232 converters. Many here recommend Keyspan but I have never used them. I use the Omron one, it is not inexpensive but has worked with everything I have thrown at it.
Here is a link to Omron cables
http://forums.mrplc.com/index.php?app=downloads&showfile=349
As above - check your cable - Omron serial ports are not standard.
For example pin 5 is a 5VDC supply for the connection of bluetooth serial ports - that is not standard.
Hello Can anyone help me I am fairly new to Omron and have not used it for about 2 years I am trying to get online to a Omron CQM1 PLC CPU21 I...
3,616
Hi! Has someone a pinout and/or wiring diagram for an old CQM1-CIF02 cable? Thanks!
1,908
Hi; I have a DUPONT brand machine having OMRON PLC CQM1-CPU21-E. I have CX Programmer installed in my Laptop having W1indow10. I want to go...
3,627
Dear All, Does anybody knows Omron CQM1 0ch Module details?? or manual i try to search but cant find manual or complete order code if this...
2,377
Hi, I've been asked what is involved to upgrade and old CQM1-21 Omron PLC to a CJ2M. I have the old file with an extension of .cdm and searches...
1,589
