Omron cqm1 problem getting online
SMAXA6
Jan 2013
Reading
Hello Can anyone help me
I am fairly new to Omron and have not used it for about 2 years
I am trying to get online to a Omron CQM1 PLC CPU21
I have had it online about 2 years ago and made a program which is running
I have made a serial cable and this worked before.
I am using cx programmer v 6.1.
I use auto online and see the yellow lap flashing on the plc as if it is communicating.
After auto online i just seem to have an empty program on my laptop in offline mode but can my old program running on the plc outputs.
Any ideas would be appreciated
If you are getting online and can see the run or monitor buttons depressed in CX-P then drop down 'PLC' 'Transfer - From PLC. There will be no comments - those old tigers did not store comments - but you should be able to upload the program. Make sure you transfer from PLC not to PLC or you will erase the program.
hello Bob
I am not getting online
I use auto online
The CX program asks me "do you wish to transfer program from plc after onlined automatically?"
I click yes. it then does auto search
using com1 9600, even, 7,2
on the plc I see the com2 lamp blinking as if it is communicating
then on my laptop i get an Untitled -cx program which has no ladder program in it. It is offline , the run , monitor all operating modes are greyed out.
under PLC the transfer to and from PLC are all greyed out.
There are no error messages to be seen
Dear Sir, Our company have a wetwipes machine an it's using a Omron cqm 1h cpu21 ,now that cpu showing err/alrm led lit and comm flashing...
4,669
Hello So we have an orange sizer that uses omron cqm1 cpu-45 the problem is the sizer was stored for so long and there is a chance the plc was...
2,425
Hi to everyone, I need little help with above mentioned CPU which was faulted few days ago. I have managed somehow to clear memory fault...
4,401
Dears, i have a problem with a labler machine .the problem is when we try to run the machine ,the machine not respond . when we checked the plc...
6,028
Hi guys! New here. Great site... yada yada yada...:D . I found this old Omron CQM1 PLC lying around in our store and started to play around...
5,247
