Omron CS1 to Ethernet VSD
Steve_D
Jul 2002
Albury/Wodonga
92
Guys,
I am trying to configure a Variable speed drive on my ethernet/IP network on my CS1H PLC. All I need to do is read the speed, status etc i.e. no control.
Omron have a network configurator package on which I can see my CPU and EIP21 Card - I assume I insert the Drives EDS files, which I did, but when I goto upload my configuration, the drive has a "Vendor Specific Error".
I just want assurance that Im heading down the right path and any pointers what to do when I get past this roadblock.
You are heading in the right direction.
The issue may be the vendor EDS file. You need to make sure it is an Ethernet/IP EDS file and not a DeviceNet file.
Also, make sure the drive is Ethernet/IP and not Ethernet TCP/IP.
Have run into this in the past.
Hope this will help.
I am investigating the feasibility of using a QuickPanel in conjunction with an Omron CS1 (with CS1W-ETN21 module) on an Ethernet network and...
3,539
The logic seemed to convert nicely, and I had to make changes to the addresses for my AD and DA and 32-point input cards. The current problem is...
1,041
Can I remove this unused module SCB41? I am Looking for reduce the power drawn from the power supply. I calculated that all modules in the rack...
1,612
I am an experienced programmer, but new to omron, but am working through that without too much trouble. I have a CS1W-PNT21 profinet card...
4,482
I've check the Omron website and looked through the CS Operation Manual, Reference Manual, and Programming Manuals. I'm looking for a pinout of...
4,218
