OMRON CS1 to Siemens Profinet interfacing
FATController
Mar 2006
Sydney
I am an experienced programmer, but new to omron, but am working through that without too much trouble.
I have a CS1W-PNT21 profinet card installed, and have a database for a siemens PLC with data I need to read and write.
I am at a complete loss how to acheive this.
I expected CX-Configurator FDT to do this without too much trouble, but it appears it is purely for configuring slave devices that have a pre-defined configuration GSD file.
Can somebody please give me a little direction?
Thanks for the replies. That looks a bit difficult, especially as we require a large amount of data transfer, and all I have is siemens database addressing in an existing PLC.
I realise now that the sales person at Omron was trying to sell us a Profinet card, telling us it will talk to siemens PLC, when he obviously knows nothing about it.
I think it would be a rediculous amount of work to get it functional even if it is possible, so thanks Omron for wasting my time.
I have decided to go with the Red Lion Data Station Plus.
It does both Omron FINS and Siemens S7 Ethernet TCP/IP and can map between them. Pretty simple configuration, the way is should be.
It looks good anyway. Anyone got any comments on this?
The logic seemed to convert nicely, and I had to make changes to the addresses for my AD and DA and 32-point input cards. The current problem is...
1,038
Guys, I am trying to configure a Variable speed drive on my ethernet/IP network on my CS1H PLC. All I need to do is read the speed, status etc...
1,573
Can I remove this unused module SCB41? I am Looking for reduce the power drawn from the power supply. I calculated that all modules in the rack...
1,611
I've check the Omron website and looked through the CS Operation Manual, Reference Manual, and Programming Manuals. I'm looking for a pinout of...
4,217
I'm looking to send ASCII strings through a SC1W-SCB21 communications module to a remote device. I've done similar applications with AB and with...
2,572
