Omron CS1G- Cpu43
valerianlin
Feb 2017
ontario
18
Hello,
I am fairly new to PLCs and have little experience with them so I thought if anyone here could help it would be great. The project that I have been given involves the OMRON CS1g- CPU 43 provided by the school. Once I plug in the power supply, the ERR/ALM red indicator lights up right away without any of the other indicators other than RDY from the CPU and POWER from the power supply.
I have tried a direct serial connection from the PC to the PLC using the RS232 Dsub 9 pin and have tried auto online/direct connect, and after auto searching for a while the error comes up which says failed to connect to the pLC. I Googled the ERR/ALM indicator and found out that it was a fatal error however am not sure which one because I can't even connect the PLC to the computer properly. I have tried at least 3 other PLCs all of which are the same model but to no avail. They all have the same problem. I should mention these models are quite old they have been sitting in the closet for god knows how long.
Anyways my question is does this fatal error prevent me from properly connecting to the PC? Is there a possible remedy? I'm running a bit behind schedule so I'd appreciate anyone help.
Thank You
I am new to cx-programmer and I'm trying to create a simple programm to begin with. I have one input and one output digital module and one output...
1,784
I was called out to a site today that I had never been to before. They have an Omron CS1G-CPU43H that was communicating to a NT21-ST121B-E HMI via...
1,451
I am working on a project and our Omron HMI looks for an address to set of an event in the log. example address is 1234.12 However in the PLC...
1,261
Hi all, I just had a question about the CS1G CPU43 and a on a time restraint. I have read the manual and found that to connect to this I need a...
4,037
Can anyone tell me what software (CX-Programmer?) and cable I would need to upload the program from a CS1G-CPU42H? I assume that there will be no...
2,112
