Omron CS1G Shows COMM but PLC failed to connect
valerianlin
Feb 2017
ontario
18
Hi all,
I just had a question about the CS1G CPU43 and a on a time restraint. I have read the manual and found that to connect to this I need a CS1W-CIF31 an a XW2Z-500S-CV 9 pin female and male. Unfortunately I don't have the CS1W-CIF31 so I used a third party connector a sabrent usb to serial connector. After installing the drivers for the usb converter I plug it in and the indicator PRPHL/COMM lights up yellow, so I know I am using the correct cable. When I click auto connect on CX-Programmer, the PRPHL/COMM starts blinking which means the two devices are trying to communicate with each other but I am still getting a PLC failed to connect. I also connected the PLC directly to the PC using the XW2Z-500S-VC but had the same problem so I don't believe the usb converter is the issue here. Do you have any solutions to this problem? Manually connecting via cx-programmer does not work as well. I am running the latest CX-Pogrammer trial version on windows 7.
Thank You.
Hi gclshortt,
Thanks for replying. For now I'll use the windows 7 pc to try and connect when I get back to school. This is odd because the COMMS indicator is lightning up and blinks when I try to auto connect. I have already set all the settings to default, and made sure the port settings in device manager matched the toolbus default settings when I use manual connect.
I was called out to a site today that I had never been to before. They have an Omron CS1G-CPU43H that was communicating to a NT21-ST121B-E HMI via...
1,453
I am working on a project and our Omron HMI looks for an address to set of an event in the log. example address is 1234.12 However in the PLC...
1,261
Hello, I am fairly new to PLCs and have little experience with them so I thought if anyone here could help it would be great. The project that I...
2,351
Can anyone tell me what software (CX-Programmer?) and cable I would need to upload the program from a CS1G-CPU42H? I assume that there will be no...
2,113
Hello and good morning people, I have this question about a plc omron CS1G-CPU42H. And my question is, if it's possible a full migration to a...
1,505
